Resolved! Solved
Camera shutter sound | S23
(Topic created on: 01-22-2025 10:47 AM)
nimeshmishra
Can I turn off the shutter sound when capturing photos in S23 base....I don't want others to know that I have clicked a photo.
Wodehouse
Mute system sounds. Perhaps it can help. Method 1.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
6 Comments
Wodehouse
Yes, you can turn off the shutter sound on your Samsung Galaxy S23 base. Here's how:
Method 1: Quick Mute
* Open the camera app.
* Tap the volume down button until the volume is muted.
Method 2: Camera Settings
* Tap the settings icon (gear) in the top left corner.
* Scroll down to "Shutter sound" and turn it off.
Note: This will mute the shutter sound only for the camera app. If you want to mute all sounds on your phone, you'll need to go to the phone's settings and turn off sound.
nimeshmishra
There is no option of shutter sound in s23
Wodehouse
Jerry770
goodthings
Kindly mute system sound then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
