Camera shaking and vibration issue
(Topic created on: 04-20-2025 12:26 PM)
rahulkhorwal
Device Model: Samsung Galaxy S25 Ultra Software Version: S938BXXS1AYC2 Issue Noticed Since: April 19, 2025 Purchase Date: February 2025 --- Issue Description: I am experiencing a vibration and shaking issue with the camera on my Samsung Galaxy S25 Ultra, specifically when zooming in or zooming out. The camera view becomes unstable, vibrates/shakes continuously, and makes it impossible to capture clear images or videos. This issue occurs: In both Photo and Video modes While using the rear camera Under all lighting conditions Attached: A screen recording showing the issue: Screen_Recording_20250420_115722_Camera.mp4 --- Troubleshooting Steps Taken: 1. Restarted the device 2. Cleared Camera app cache and data 3. Confirmed software is up to date (S938BXXS1AYC2) 4. Tested in Safe Mode – issue remains 5. No signs of physical damage or lens obstruction --- Request: Please investigate and advise a resolution. If the issue is hardware-related, I am open to visiting a Samsung service center or following your guidance for repair or replacement. As this affects a key feature of the device, I request prompt support. Thank you, Rahul Khorwal
rahulkhorwal
Bro service center se replace krwana pdega lens
Apne replace kraya?? Esa kya guarantee hai ki dobara nhi hoga kuch bole service center wale
lazyostrich9
Did you replaced your lens
rahulkhorwal
There is no other way bro
lazyostrich9
But In few cases the issue is still not resolved even after replacing the lens
rahulkhorwal
After replace my camera work well
Prafulk
Do you have the details on what was changed? How sure you are if they have replaced it with the right kind of lens? Have you received any detailed report please?
rahulkhorwal
Bhai Ultra wide lens replace kra new dala mene dekha phle sab verify krke hi krwaya
Ro0hit
me facing same issue / dont want to open device / want replacement with new one
Prafulk
Im also facing the same problem with the recently purchased s25 ultra and this is a manufacturing defect.
I am noticing this after April software update
