Camera shaking and vibration issue
(Topic created on: 04-20-2025 12:26 PM)
rahulkhorwal
Device Model: Samsung Galaxy S25 Ultra Software Version: S938BXXS1AYC2 Issue Noticed Since: April 19, 2025 Purchase Date: February 2025 --- Issue Description: I am experiencing a vibration and shaking issue with the camera on my Samsung Galaxy S25 Ultra, specifically when zooming in or zooming out. The camera view becomes unstable, vibrates/shakes continuously, and makes it impossible to capture clear images or videos. This issue occurs: In both Photo and Video modes While using the rear camera Under all lighting conditions Attached: A screen recording showing the issue: Screen_Recording_20250420_115722_Camera.mp4 --- Troubleshooting Steps Taken: 1. Restarted the device 2. Cleared Camera app cache and data 3. Confirmed software is up to date (S938BXXS1AYC2) 4. Tested in Safe Mode – issue remains 5. No signs of physical damage or lens obstruction --- Request: Please investigate and advise a resolution. If the issue is hardware-related, I am open to visiting a Samsung service center or following your guidance for repair or replacement. As this affects a key feature of the device, I request prompt support. Thank you, Rahul Khorwal
25 Comments
goodthings
goodthings
Your's most welcome to here.
Rounak98
Do you mount your phone on bike or anything?
rahulkhorwal
No bro
Rounak98
Then I believe there's no physical damage to the OIS. But your phone is facing some different issue. If you bought it from a physical store visit it once else visit service center. I also faced camera issue when I bought my s24 ultra. They replaced the device within a day. I hope it helps you.
Rounak98
Looking at your video clips it seems it's not a software issue rather a physical issue with the OIS. Don't worry service centres will help you out without any charges.
rahulkhorwal
Bro i don't know what's the reason behind this but im sure in my phone not physical damage and other issue
cs_member8
Dear Samsung Member,
As you are facing multiple issues on your device, kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve the issue.
Path: Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
Same issue. Samsung is not taking any responsibility on this. Neither providing a clear resolution. All they say that technical team is looking into. I haven't visited the service center yet as I am worried that phone will get open just in 2 months 🥲 waiting if they provide any software update as it happened post april update
