Camera problem
(Topic created on: 04-22-2024 02:11 PM)
MyS22
Samsung s22 gives blurry and useless pictures in 3x portrait mode. I'm using this phone 1 year but now I'm facing this camera issue 😔
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Kindly check first if there are any broken camera lenses or scratches on the camera, no laminated or tempered glass is pasted on the camera if not then check after the camera lens cleaning.
Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprints, dirt, and dust from the camera lens.
Reset the camera settings: Home screen tap on Camera>Settings>Reset settings>Reset.
Clear camera application data: Apps>Camera>Storage>Clear Data
Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
