07-21-2025 01:49 PM in
Galaxy S- Mark as New
07-21-2025 02:01 PM in
07-21-2025 04:19 PM in
07-22-2025 08:52 AM in
Galaxy SDear Samsung Member,
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
07-27-2025 11:01 PM in
Galaxy SI did all the steps mentioned and at last I did format my phone but still issue persists..when opening camera and zoom in and out then it's start flickering camera with some noice..please help here..
@krishsolanki00q is your issue resolved?
