Resolved! Solved
Camera lag problem in s24 ultra
(Topic created on: 08-29-2024 10:56 AM)
Prince_2922
Iam facing a camera lag problem in my s24 u since many days.
The camera application lags...when i open it
goodthings
8 Comments
Tech_xplorer
Tried Clear cache?
Prince_2922
Yes...i have cleared the cache. But still facing same issue
mudassarfa
  • Clear Cache: Go to Settings > Apps > Camera > Storage, and clear the cache.
  • Disable Scene Optimizer: Turn off the Scene Optimizer in the camera settings.
  • Restart Phone: A simple restart can often resolve temporary issues.
goodthings
Please clear catche and clear data of this app and reset camera settings also reset all settings of your's device in general management settings then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
Prince_2922
Still facing same issue
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Reset the camera settings: Home screen tap on Camera>Settings>Reset settings>Reset.
Clear camera application data: Apps>Camera>Storage>Clear Data
Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
