Resolved! Solved
Camera issue with Samsung S21 FE
(Topic created on: 07-13-2025 02:46 PM)
Raowl10
Beginner Level 4
Hi Members,
I have encountered issue with my samsung s21 fe, camera does not focused by itself even after touching screen it doesn't focused. Although it works when I shake the phone but after moving around phone a bit, i need to shake it again. Anyone knows what is this issue ? Please let me know.
Thank you
harsharma1801
You can visit authorise service center/ shop to ensure this issue.
If they conform then went for change.
Thanks plz accept this ans if you satisfy with reply.
4 Comments
harsharma1801
It may happen if you drop your phone
Due to which the OIS is present in the camera module gets unstable and may result in a blurry image
Raowl10
Beginner Level 4
Thanks for replying
So do I have to replace whole camera component ?
harsharma1801
cs_member10
Dear Samsung Member,
● Kindly check the physical condition of your camera lens, such as broken camera lens or scratchy camera lens.
● Kindly camera lens cleaning: Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprints, dirt, and dust from the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
