Camera Shifting Problem
(Topic created on: 06-12-2024 10:25 PM)
parabrahma
The major problem I noticed on my Samsung Galaxy S24 Ultra is while zooming in and out. The camera abruptly starts shifting while recording. The entire video gets ruined because of this camera Shifting issue.
I have attached a video which shows 2 things camera Shifting while focusing and zoom.
Zooming in and out in video or photo mode has the same outcome. Videos come out bad because of this. This is a super expensive phone to have any such problems.
6 Comments
Sravan_
I also did face this issue alot of times bro 😮💨
tushu11
The same issue i am also facing
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share the same video clips for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
parabrahma
This problem does not occur in the Galaxy S23 Ultra then why is it happening in a brand new Galaxy S24 Ultra? Need a permanent solution ASAP.
parabrahma
Why isn't Samsung acknowledging this issue in such an expensive phone. Own up to the mistake and try to make it right.
DoctorAsif
Turn off the focus enhancer option in camera then this will be solved. Actually whats happens is that in galaxy S24U near objects are focused with ultrawide lense and as soon as you move to focus distant object, camera shifts to main camera lense. This lense shifting causes a parallax shift as observed in your video. This occurs total automatically. But luckily you can disable this. After disabling focus enhancer the phone uses only main lense for both close and distant objects os dynamic video shots like yours. This solved my problem because I also own galaxy s24U. But I think this same issues also present in iphones 16 pro max which I also own. Actually this is a feature rather than an issue and can easily be changed if it bothers you.
