Resolved! Solved
Camera Focusing issue
(Topic created on: 12-23-2025 09:28 AM)
Bappi1
I think i am facing Focusing issues on my s24 ultra's camera. Is there anyone facing the same issue? How to remove the issue? If anyone can solve the problem, let me know. I will be greatful.
goodthings
Please clear cache and clear data of this app and reset camera settings also turn off Auto HDR also reset all settings in general management settings also flight ✈️ mode on and off one time also optimize your's device in device care too also clear cache of all Apps manually also update your's all Apps too then try to it's again. If you like please accept it's a as solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
3 Comments
goodthings
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
● Kindly check physical condition of your camera lens.
● Kindly clean the camera lens by microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt and dust from the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
