Call echoing problem
(Topic created on: 08-14-2024 07:22 PM)
akdey
Hi Team,
Is there a known issue with Samsung Galaxy S24 ULTRA with call quality ? I am.using jio Sim and sometime intermittently on inbound or outbound call I hear my voice echoing back to me and I can't hear other party. Other party confirmed that they can hear me though.
Have sent the error report as well in feedback section.
2 Comments
StarShree
I too faced this with jio. Jio is just shitt. I ported to airtel n now 00 issues.
Accept solution by clicking 3 dots of the comment
cs_member10
Dear Samsung Member,
Reset the device Settings:  Settings > General Management > Reset settings>Reset all settings to their default.
Increase the call volume: Ensure that the volume on your device has been set to the highest level during a voice call. You can also try tapping on the speaker to see if this improves the call volume.
*During a voice call, press the volume button of your device, to open volume settings.
*Tap and drag the call volume bar to left or right to increase the call volume.
Disable mute all sounds feature if enable: Settings> Accessibility> Hearing enhancements> Disable Mute all sounds, if enabled.
You can reset your device by following the steps.
Also, you have already share logs with our dedicated team , we request you to please kindly wait for the revert from the technical error team end.
