Bug-S24 Ultra Battery information flickers when charging
(Topic created on: 02-16-2024 05:18 PM)
omkarg81
When the S24 Ultra is put on charging and the battery information is shown, the text seems flickering where the brightness keeps increasing and decreasing all the time, which seems to be a bug.
On other occasions even with AOD on the text on the black screen doesn't flicker but only during battery charging.
Please fix this at earliest.
12 Comments
yes it is due to sensor. But even with constant light it is behaving like that
ag_1436
Beginner Level 3
Lmao. that is probably your celing fans causing it to constantly change its brightness to adjust to ambient brightness.
Put your palm over the front camera location. and it will stop doing that.
Roni2004
Beginner Level 3
Same problem please help to fix 🙏🙏🙏
