Bluetooth problem S22 ultra
(Topic created on: 01-04-2024 12:09 PM)
ÑôŤëńĐ
I have a problem with my S22 ultra mobile phone after the last update. Connecting to Bluetooth is difficult when i have a call is okay but when I open any audio it does not work. So
 I disconnect it and reconnect it. Than it works.but after any call i have to make this operation than I reset the settings of the phone It was repaired for a short time and then it came back again. What should I do?
Try to wipe cache partition. And did you Joined beta?
ÑôŤëńĐ
No
Try
And you were in beta?
Zammi
S22 ultra received One UI 6.0 with the December update.
First try to reset settings.
1. Unpair all your Bluetooth devices.
2. From the settings, search for Reset and tap on Reset Wifi and Bluetooth settings option. Complete it and restart the phone. You will have to reconnect to your WiFi again. Pair your Bluetooth device one at a time and test.
If it doesn't help, follow below steps to clear the cache partition.
It will not delete any data. But you should connect your phone to a PC with charging cable before you start.
Yasin1
Some issue facing... but not a connction issue.... volume not coming up...
ÑôŤëńĐ
Yes
Samsung_specialist
Forget and Reconnect Bluetooth Device:
Go to Settings > Connections > Bluetooth.
Find the paired Bluetooth device causing the issue.
Tap on it and select "Forget" to remove the device.
Reconnect the Bluetooth device by pairing it again.
Clear Bluetooth Cache:
Go to Settings > Apps.
Tap on the three dots in the upper right corner and select "Show system apps."
Scroll down and find "Bluetooth."
Tap on "Storage" and then select "Clear Cache."
Restart Your Phone:
Sometimes, a simple restart can resolve temporary glitches. Restart your Galaxy S22 Ultra and check if the issue persists.
Reset Network Settings:
Go to Settings > General management > Reset > Reset network settings.
This will reset Wi-Fi, Mobile data, and Bluetooth settings. You'll need to reconnect to Wi-Fi networks and pair Bluetooth devices again.
Update Software:
Ensure that your device's software is up to date. Go to Settings > Software Update and check for any available updates.
Safe Mode:
Boot your phone into Safe Mode to check if a third-party app is causing the Bluetooth issue. In Safe Mode, only pre-installed apps will run.
Press and hold the power button until the power off screen appears.
Long-press the "Power Off" option until you see the Safe Mode prompt.
Tap "Safe Mode" and check Bluetooth functionality.
Wipe Cache Partition:
Turn off your Galaxy S22 Ultra.
Press and hold the volume up button and the power button simultaneously.
Once the Samsung logo appears, release both buttons.
Use the volume buttons to navigate to "Wipe cache partition" and use the power button to select it.
After the process is complete, reboot your device.
ÑôŤëńĐ
Operation Success But patient Died.....
The problem is still not solved..
ÑôŤëńĐ
