01-04-2024 12:09 PM in
Galaxy S- Mark as New
01-04-2024 12:28 PM in
Galaxy Sas you mentioned it occur after last update. Most probobly it is software issue. Wipe the cache partition. And if possible rest. Dont worry for you can backup data using smart switch. Into any external device. Or into cloud as you prefer. Try to reset you bluetooth device. And re pair it. Try to check that device with other devices.
01-04-2024 12:52 PM in
01-04-2024 01:06 PM in
Galaxy SJBL tune 125bt
01-04-2024 01:10 PM in
01-04-2024 01:11 PM in
01-04-2024 01:12 PM in
01-04-2024 01:13 PM in
01-04-2024 12:53 PM (Last edited 01-04-2024 12:54 PM ) in
01-04-2024 01:09 PM in
