Bluetooth issues of s23 ultra with huawei Freebuds 4
(Topic created on: 05-19-2023 03:50 AM)
AbdullahAzhar1
After pairing it started working good but after few minutes it got disconnected from and show calls only and kept pairing with the Bluetooth any solution for that
g112
Beginner Level 3
Same problem with me also
ahmedyousry2
Same issue it seems to bug in s23 ultra
RashiPalora
I think it is a big bug with S23 ultra, I had connected the same Freebuds 4 with old Note 10 Plus and it was working like a charm.
Does anyone know will it have the same issue with Samsung Galaxy Live Buds also ?
Thanks
Same thing with me as well its working with all other devices except S23 ultra
RashiPalora
Yes, need to check how Samsung Budd Live with S23 Ultra
RashiPalora
Very annoying, Even samsung doesn't have any idea... they said compatibility issue... No answer when I told them... Huawei worked well with Note 10 Plus
andferrario85
Beginner Level 3
Same issue there on a brand new S23 Ultra. Freebuds4 was working perfectly with my previous S10+
Seems to be a phone fault, it loses connection to audio and only keeps connection for calls. Only way is to put earphones again in their case and take them out again.
Tried to reset phone, earphones, unpair, pair again, delete cache and data of Bluetooth services, ... no results.
All software is at its latest update.
Very disappointing!
Yup even updating software facing same issue i hope they'll sort this out in next update finger crossed 🤞
RashiPalora
For the above said issue, solution is, buy samsung galaxy buds... I tested it and working... I think it is samsung tricky play...to buy their products...
fahadq8y
I have same issue I tested
My freebuds 4 with many phones
Like Lenovo and OnePlus
It's working without any problems
Just in Samsung s23u
And my brother have same issue
He have freebuds pro and Samsung s22u
That's bad trick from Samsung
