Bluetooth issues of s23 ultra with huawei Freebuds 4
(Topic created on: 05-19-2023 03:50 AM)
AbdullahAzhar1
After pairing it started working good but after few minutes it got disconnected from and show calls only and kept pairing with the Bluetooth any solution for that
42 Comments
salmanul
1. Compatibility check: Make sure both devices can actually play nice together.
2. Update time: Ensure your Samsung S23 Ultra and Huawei FreeBuds 4 have the latest software updates installed.
3. Restart and reconnect: Give both devices a restart and then reconnect them to see if that does the trick.
4. Battery optimization off: Check if there are any pesky battery optimization settings messing with your Bluetooth. Disable them if needed.
5. Get some expert help: If all else fails, reach out to Samsung and Huawei support for some tech-savvy assistance.
Samsung_gQCqZbA
Beginner Level 3
Dear,
the problem was solved after changing the Battery optimization to Unrestricted.
Many Thanks.
Not applicable
This is absolutely not working advice. It has nothing to do with solving the problem.
Sometimes it is better to remain silent.
salmanul
If you connected same Bluetooth device with another phone or something,try to unpair from that also
Samsung_specialist
Hello,
Kindly try to reset the Bluetooth Device and enter it in the pairing mode by referring to their manual. Turn Airplane mode on and off. And check the software update if it is up-to-date for both the device and the Buds.
If the issue persists, kindly try to reset the network settings by following these steps, It will erase saved Wi-Fi passwords and Bluetooth connections.
Step 1 Swipe up or down to view the apps.
Step 2 Press Settings.
Step 3 Scroll to and touch General management.
Step 4 Press Reset.
Step 5 Press Reset network settings.
Step 6 Press Reset settings.
And then try to do a soft reset for the device by pressing and holding the Power button and the Volume down button simultaneously for more than 7 seconds to restart it. This will Not delete any data from the device.
If the problem persists, please send us an Error Report by following the steps below.
Head to the Members app > Get Help > Error Report > Tap 'OK' to send System Log Data > Select the symptom, and include as much detail as possible.
To ensure your logs accurately reflect the issue you're experiencing, we'd like you to submit your report within 5 minutes of encountering the problem. Our engineers will then investigate this and respond to you with a solution via the Members app.
Tried everything but no use still facing same issue
fadi
I have the same issue
Bobby66
Beginner Level 3
Same problem. No way to solve it.
Wibowojh
Beginner Level 4
Same problem with me.
