Bluetooth Problem in s23
(Topic created on: Saturday)
Adwaith9182
So I have been using my wireless earphones for a llong time , recently after an update whenever I receive any calls during when I scroll through instgram or watching youtube the media sounds gets shutdown and I have to restart my phone for media sounds why it that ?
15 Comments
Wodehouse
Possible Causes
1. *Software conflict*: The recent update might have introduced a bug or conflict with your earphones' drivers or firmware.
2. *Audio focus issue*: Android's audio focus system might be causing the media sound to shut down when a call is received.
3. *Earphone compatibility*: The update might have changed the way your phone interacts with your earphones, leading to compatibility issues.
Troubleshooting Steps
1. *Restart your phone*: You've already been doing this, but try restarting your phone in safe mode to isolate the issue.
2. *Clear earphone cache*: Go to Settings > Connections > Bluetooth > Your earphone's name > Clear cache.
3. *Update earphone firmware*: Check the manufacturer's website for firmware updates.
4. *Reset earphone settings*: Reset your earphone settings to their default values.
Additional Tips
1. *Check for software updates*: Ensure your phone and earphones are running the latest software.
2. *Contact earphone manufacturer*: Reach out to the earphone manufacturer's support team for assistance.
3. *Try a different audio app*: Use a different audio app to see if the issue persists.
If none of these steps resolve the issue, it's possible that there's a hardware problem or a more complex software issue at play.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
Adwaith9182
Hii , I couldn't find absolute volume in my connections and also couldn't find clear cache
Is there some other fix to it ?
Zen_Uchiha
Having same issue on my S23. I've accepted that it's a software update issue but as i use my bluetooth earphones on a daily basis...restarting the device many times makes it's very annoying!
Adwaith9182
Same brother, its too annoying , we definitely want a fix to this
Zen_Uchiha
Yes! if you get any solution! please post it here!
Adwaith9182
Yep
Zen_Uchiha
bro did you unofficially tried to go into one ui 7 beta?
Adwaith9182
Nope I didn't install it just scrolled that's it
Zen_Uchiha
actually I installed it unofficially! and then when i downgraded to one ui 6.1 again! i started having that bluetooth issue!
