Biggest problem solved in s21fe
(Topic created on: 12-23-2023 08:51 AM)
VyomTrivedi
I am having S21fe(exynos) and was facing the biggest problem in s21fe, which is battery backup. After one ui 6 update, the problem of battery backup is solved to a great extent. Before one ui 6, the ideal battery drain was around 5 to 6 % overnight but now it's around 2 - 3 and SOT is far better than before.
So, I am happy with the update thank you 😊
11 Comments
VyomTrivedi
You should try to restart it and set auto optimization on from the device care 1703481847685.jpg
yogiSR09
how much sot is good with 5g on and 120hz on??
