Prvn1997
11-10-2024 12:38 AM in
Which one is better..
2 Comments
Tech-Savvy
11-10-2024 01:42 AM in
"Maximum" is the best option among the list.
Your selection depends on you.
If you want a longer battery life, select the Basic or Adaptive option.
If you want to save your battery life as much as possible, select the Maximum option. But do remember that your phone doesn't charge over 80%
MOQBALI
11-11-2024 01:36 PM (Last edited 11-11-2024 01:40 PM ) in
Adaptive is typically the best compromise because it maximizes convenience while taking care of battery health. However, if you prefer to manually manage charge levels or have a specific need for 80% capacity, you could choose Maximum.
