Battery drain after April 2026 Security Update
(Topic created on: 04-26-2026 07:00 PM)
TounysTech
Any one else using the S24 Ultra is facing major battery drain and less SOT after the April 2026 Security update? And did you find a solution
2 Comments
تحديث
Samsung_specialist
Thank you for sharing your concern.
Regarding battery drain after the latest update, kindly note that it is normal to experience temporary increased battery consumption after software updates, as the device runs background optimizations and adapts to usage patterns.
To improve battery performance, please follow the steps below:
  1. Restart the device
  2. Optimize the device from: Settings > Battery and Device Care > Optimize Now
  3. Check battery usage from: Settings > Battery and review any apps consuming high power
  4. Ensure all apps are updated via Galaxy Store and Google Play
  5. Reduce background app usage and disable unused features (such as location, Bluetooth when not needed)
  6. Allow a few days for the device to stabilize after the update
If the issue persists, you may consider performing a factory reset after backing up your data.
We appreciate your feedback, as it helps us improve future updates and overall performance.
