Battery usage per app percentage usage does not quite add up
(Topic created on: 02-20-2022 12:29 PM)
Inminet
Greetings,
Please look at the screenshots. I added each app percentage battery usage(~42%) and added it to the total battery juice left (~33%) and I add these to get 75% which is 10% short of 85%(max amount of battery I charge).
Is the samsung's battery usage app calculate it wrong? I can understand some error is normal, but this is 10% error we are talking about, not 0.1% error. Is this the case with everyone or is it only my device(s20 fe 5g)?
Samsung battery usage calculation
Samsung battery usage calculation 2
12 Comments
kau
Are you using always on display
Inminet
Yes, but that comes under one home ui right?
Souraaav
Nope, it doesn't come under one ui home
ㅤ
this long screenshot...🤥...
pls tell me tell me.. 😃 ..how to take this... long screenshot..
Inminet
When you take screenshot, you get a bar at bottom a second which gives you multiple options like scroll screenshots, edit etc.Screenshot_20220220-133423_Samsung Members_13727_1645344342.jpg
ㅤ
🤦 maine toh yeh option band kr rakha tha.. 😂
isiliye mujhe nhi ptaa
kau
No are you using it always on or tap to show
Inminet
Tap to show
mHappiee
Device hardware like wifi, NFC, mobile data, etc also needs battery to run...
And some core ir system apps are not counted ig 🙃
