Battery saver not working when using jio 5g
(Topic created on: 01-13-2023 06:47 PM)
LGk
Using s20 fe 5g battery saving not working when using 5g. We must do the above process to enable battery saving.
8 Comments
Yes it's not working in my device also s20 fe 5g
Doctrdope
Battery saver has default turn off 5g option. Disable it. You can use it on 5g
DsFouzdar
5g will not work in battery saver
帕里克
Working battery saver with 5gScreenshot_20230114_155937_One UI Home_1000041323_1673692177.jpg
LGk
How is possible?
LGk
Kindly tell how?
帕里克
Use adaptive battery. When battery goes to 50% than power saving activated itself but 5g will stay on. It will effect only on background apps.
cs-member11
Dear Samsung Member,
We acknowledge your query and apologize for the same. We would request you register your concern in Samsung Members Application. So, our concern team gets back to you as soon as possible.
Please follow this path to register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Note. please attach the error log file within 15 minutes of the error occurring.
