Battery life and heating issues improved after May security update !
(Topic created on: 05-22-2025 03:36 PM)
ankitpsy123
Can see major difference , anyone who feels same ?
On s24 ultra
9 Comments
L_u_f_f_y
Dude we just got the update, how can you see the differences so fast ? Moreover the screen lock lag is still there.
ankitpsy123
Clear cache partition and cache from individual apps in settings , use performance profile to standard and then see ! Difference is massive , i restarted twice, and then played some heavy games ! Difference is noticeable
ankitpsy123
My was overheating on normal use, now its like way better, its just my experience !
Is there any improvement other than battery and heating issue in May update.
ankitpsy123
What else was required ? Everything else was okish
There was multiple issue in one ui 7 but takes lot of time to mention. See my post for issue in beta and stable one ui 7 and a news link for changes from one ui 6 to 7 link is given below
https://search.app/3173s
L_u_f_f_y
On my device no noticeable changes , as useless as before
ankitpsy123
What went wrong
L_u_f_f_y
I don't play games the only thing which has been the most annoying is the lock screen lag, minor battery drain issue. I literally have to make all the animations to .5x in order to avoid the lag.
