Resolved! Solved
About Battery Drain & Heating Issue
(Topic created on: 05-21-2025 09:25 PM)
Abhi_Germany
Hello Dosto..
Jab Se ONE UI 7 Update Kia H Joki 20 Din Ho Gaye H..
Tab Se Mere S23 Ultra Me Battery Drain Or Heating Bahut Jayada Ho Rahi H Normally Use Par Bhi__
Kya Kisi Or User Ko Bhi Same Issue Ho Rahe Update Karne K Baad__
Comments Karke Bataye-->>
2 Solutions
goodthings
goodthings
Your's most welcome to here.
11 Comments
Thunder404
I am aslo facing battery draining issue and network connectivity issue.
Abhi_Germany
Is This Happening After Updating To ONE UI 7??
I am also facing heating issue or battery drain issue🔥
Lds
Sab ka yahi haal h
Abhi_Germany
Pata Nahi Kaisa Update Diya Samsung Walo Nee..
Isase Badiya To Pehele Wala Hi Update Tha..ONE UI 6..
HypeBeast
I'm also facing battery and heating issue in s23
All we have to do is to wait for the next update.. hope samsung will do fix it
Abhi_Germany
Hope So Samsung 'll Fix This Problem In Next Update..
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
8. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
