a week ago in
Galaxy S- Mark as New
a week ago (Last edited a week ago ) in
Galaxy SLook at the screenshot, earlier @50% I got 4 hrs 36 mins SOT. And today remaining battery percentage is 28 and SOT is 4 hrs 18 mins. I can get another 1 hr max SOT.
a week ago in
a week ago in
a week ago in
Monday in
a week ago in
a week ago in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
