Battery drain in S23FE after one ui 7
(Topic created on: Sunday)
Abdullah5002
After one ui 7 I seen that the battery drains very fast so I reach Samsung authorized service centre, they said it maybe because of software issue it'll be solved by installing new os in your device and they reinstall the new os in my device. After the new os my mobile battery backup is nice for 5 days. After 5 days the battery is again started to drain fast.
5 Comments
Deepaks87
Yeah, I think most S23 FE users are having the same problem.
SatsangiDevan
Bugs galaxy
SaiNikhil02
For me 160% only 6hrs 53min
Yours better
BiRdMaN
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
cs_member10
Dear Samsung Member,
As per your query, we would request you visit the service centre where your product was previously inspected. They will provide you with all the information in a better way after inspecting the device physically.
