Battery draining quickly S24U BYD9
(Topic created on: Thursday)
JugalG
Battery draining 5-10% faster than usual. Instagram taking surprisingly higher battery than ONE UI 6. Anyone else facing that. Also anyone updayed to May 2025 BYE4 Update?
7 Comments
goodthings
goodthings
Your's most welcome to here.
JugalG
May I ask? If you are on S24U are you having same issues?
goodthings
No. But mostly users facing same issue also others series users too. Thanks.
JugalG
They are not taking my complaint just because my phone is USA make and I'm using it in india
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
JugalG
I have tried everything you have mentioned. Except software update as I am in India I haven't got BYE3 I have got BYE4, but I want to check the feedback from those who have updated. As I have made the mistake of updating to ONE UI 7 believing it will be optimised but it isn't and I am suffering from heating and battery drain.
