Battery drain
(Topic created on: 12-15-2025 11:20 PM)
Samsak
All the ultra models( s22,s23 to latest s25)are only given 5000 mah battery and the processor is a overclocked snapdragon version,it demands more battery power.Display also demands more power in qhd+ setting,Adavptive rate(120hz) also consumes more battery and many more that i cant even write them.These mobiles always will be equipped with 5000mah battery and it will be enough,doesn't make any sense. We buy these ultra models to keep them in 60hz,fhd+,turning on battery saver and for every update from one ui 6 ,one ui 7 and now for one ui 8 the battey drain is increasing exponentially,what a joke isn't?If any samsung employees or any one related to the company are reading my post please increase the battery capacity or optimize the battery even more.I am a big fan of samsung and i want the company to grow and produce more good products.
5 Comments
kshitij_puri
I'm having same issue with my S24 the battery optimisation is the worst. It's only a few days Old and already the battery is behaving like it's 4 year Old.
_the_Devilman
Ultra or base model?
What SOT are you getting?
kshitij_puri
S24 I haven't tested it fully but it will not last more than 3 hrs SOT.
cs_member10
Dear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concern. We are taking your feedback regarding this matter and will take it into consideration for future updates.
9. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
Same problem...payning 1.45 lakh for phone battery🤡
