Battery drain
(Topic created on: yesterday)
gamershiv
What the hell is this drain
I have been not using AOD, 5g(only 4g,4g+) even when i am home i turn off the mobile data and use wifi, only on light performance profile the whole time when i bought this and whole other things
In short, i have done all the things to reduce battery consumption and prioritise battery health over anything
This screenshot i have taken shows just a short amount but there are many times like where i only used around 20 percent and this mf took 50 percent
Samsung optimise this update
7 Comments
walker_dv
Restrict battery usage and put app to sleep when not used !
gamershiv
Bro i have done all the things
ArpanSoni20
Same with my z fold 5, hope this issue fix in may security update.
iamrohitkm
I hope Samsung will fix in next security update
blueheaven123
What they have done i don't know the battery lasts half the battery of one ui 6.1. I request Samsung to fix this asap if its not intentional.
goodthings
goodthings
Your's most welcome to here.
