Battery drain
(Topic created on: 07-20-2023 10:01 AM)
Thejas11
Recently my Samsung S20 FE 5G ,battery is getting drained faster even wen not in use ...so is there any app for the phone that I can clean up my phone?
4 Comments
Check with safe mode if its the system draining battery or some app. Or install gsam battery monitor with some permissions through adb and check usage.
Thejas11
Thanks 😊
KshitijMore
Facing the same issue
cs_member10
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Warm regard,
