Battery drain out quickly
(Topic created on: 05-06-2025 03:39 PM)
Anishahamed
Hi team samsung, am update uI-7, now i feeling battery drain out quickly. Why. Please help
Samsung S23
4 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
