Resolved! Solved
S23 Battery Draining issues after May software release
(Topic created on: 06-19-2025 07:19 PM)
Gopal-M
Beginner Level 3
Hi ,
After updating the Samsung May software updates my S23 ultra battery is draining too quickly
Before upgrade is put the charge every 28 hours . But now it's less than <8 hrs
Is any fix rollout by Samsung?
goodthings
3 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
