7 hours ago in
Galaxy S- Mark as New
7 hours ago in
7 hours ago in
7 hours ago in
Galaxy SAdd apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
6 hours ago in
16m ago in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
12m ago in
