06-28-2025 09:10 AM in
Galaxy SSolved! Go to Solution.
3 weeks ago in
Galaxy S- Mark as New
3 weeks ago in
Galaxy SMy Samsung was like that when I bought, slowly it optomized itself and I changed my usage patterns and it's better now.
But since you have last chance to replace it by today, so you shouldn't take the risk, replace it today.
3 weeks ago in
3 weeks ago in
3 weeks ago in
3 weeks ago in
3 weeks ago in
Galaxy S1. Background Sync & Setup: Right after setup, the phone runs lots of updates, app syncing, indexing, etc., which drains battery fast.
2. AI & Learning Phase: Samsung phones (especially One UI) optimize battery based on your usage over time. It usually takes 7–10 days to stabilize.
3. High Refresh Rate: If the 120Hz display is on all the time, it consumes more power. You can switch to adaptive mode or 60Hz to save battery.
4. Battery Calibration: New batteries sometimes need 3–4 full charge-discharge cycles to perform at peak efficiency.
5. Check Rogue Apps: Go to Settings > Battery and device care > Battery > Usage to check if any app is draining power unusually.
If the battery still feels bad after 10 days with normal use (no gaming, overheating, etc.), then maybe a software update or service visit would help.
Among all these tips , the only thing i didnt do was completing the 100 % charge part 3,4 times. Till today i charged only once 100% . And kept the battery protection at maximum i,e 80%
3 weeks ago in
Galaxy S3. I use 120 Hz most of the time. Doesn't make much difference.
5. You can't easily figure it out, rather put background restrictions.
3 weeks ago in
3 weeks ago in
