Resolved! Solved
Battery drain issues
(Topic created on: 06-28-2025 09:10 AM)
PARIJATRIKO
Screen off time with two background apps running 1.Internet speed meter 2.Regain This is the condition in 4 days old S24FE.Give me any solutions
Resolved!
32 Comments
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
armlinker4639
You can do the following things which won't affect your experience much:
1. Set a routine to turn ON power saver automatically when battery level is below certain level, say 45%.
2. Set Performance profile to Light as it doesn't affect day-to-day normal usage. [For Galaxy S Users]
3. Disable Adaptive Brightness as it uses the sensor and battery all the time.
4. Keep less screen time out.
5. Use Dark Mode.
6. Turn OFF Nearby Device Scanning.
7. Turn OFF Location, WiFi, Bluetooth scanning. They consume a lot of power.
8. Enable auto restart when needed.
9. Regularly clean your memory.
10. Disable RAM Plus if you don't require much memory hungry apps.
11. Uninstall the unnecessary apps which you don't use.
12. Put restrictions on which apps can run in background and which should be put to Deep Sleep.
13. Turn OFF notification from the apps you don't use much or don't need or which send you useless Notifications. They drain a lot of battery running in the background.
After doing all this report this bug through the app:
Open Samsung member application >> tap on support >> tap on send feedback >> choose composer option >> select error >> select the appropriate category >> type your query.
If this helps you, I'll appreciate if you could accept my comment as solution by clicking on the dots on the top right of my comment 😊
rixxzyy
Barely once or twice
