Battery drain issues
(Topic created on: 02-03-2025 02:42 PM)
Hitesh1011
Hello Samsung GALAXY S23 users,
Is anyone facing battery drain issues while using phone outdoors? I'm facing this issue since 29/01/25 after January update.
Please suggest me some ways to improve battery health, I usually keep on maximum mode (80%), but when I'm outdoors I switch to basic mode (100%).
6 Comments
kuma007
S23 has been facing this for quite a while now
We can hoping for one ui 7 to fix this 🧐
goodthings
goodthings
Your's most welcome to here.
jemin07
I have galaxy s 24 and same problem facing your battery outdoor side drain becomes you turned on automatic brightness so your phone is running full brightness that's your battery fast drain .
If You satisfied my solution so pls accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.😊
Ujjal4928
Few things u can do is when u charge switch off ur phone before that disable fast charging I guess these two will improve battery life but it will take time to charge sadly there's no fast charge support with Samsung like one plus oppo nd realme
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
