Battery drain issue
(Topic created on: 05-21-2025 06:05 PM)
Werqey
Any body experiencing battery issue on S24 plus... not lasting upto 5 screen time on normal usages no movie, no games noting just social media ...this is happening after the update
4 Comments
CK1o
Experiencing same on s25ultra
NOMAĐ
Everyone's experiencing the same. Wait for may update.
DipankarG
I'm also facing same issues
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
