04-23-2025 02:30 AM (Last edited 04-23-2025 02:33 AM ) in
Galaxy S- Mark as New
04-23-2025 05:26 AM in
04-23-2025 07:17 AM in
Galaxy SYou also suffering from any issues that you have? You're not alone!
Like, comment & support this post to make Samsung listen!
Click now: https://r2.community.samsung.com/t5/Galaxy-A/Samsung-s-Response-Isn-t-Enough-Look-What-They-Said/td-...
04-23-2025 07:33 AM in
04-23-2025 04:10 PM in
Galaxy SDear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
