Resolved! Solved
Battery drain issue in S25 ultra while using camera
(Topic created on: 02-07-2025 10:36 PM)
Lakshay31
I am using my S25 ultra for last 3 days and I don't think it's battery is performing as claimed by users on X. I am noticing battery drain issue while using camera it's like 1% for every 1 min.
Is anyone else also facing such issue on their device?
2 Solutions
goodthings
Your's device is new so please give it some time. After some time and After some updates all is well. So please don't bothered about this issue now. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
anilpss
Bro it happens because you shoot video in 4k and took HDR images. The image and video processing requires some additional power, at that time you might observe heating issue. It's normal there might improve device stability for future updates but they can't resolve your issue for 100 % let's hope for the best...
Enjoy with latest flagship from samsung it's one of the best phone. Don't think much. You are getting 7 hrs screen on time so your device is in excellent condition 👌
Happy weekend
12 Comments
Timothy2
Expert Level 4
It's a degraded version of the S24 Ultra. The camera ring will easily come out; there is no Bluetooth S Pen. Check JerryRigEverything on YouTube.
Lakshay31
Come on, Camera rings didn't come out easily even for jerry he had to put a lot of force for that
Timothy2
Expert Level 4
It's a degraded version of the S24 Ultra, except for the Snapdragon Elite.
anilpss
Camera is more graphic intense application, it uses both CPU and GPU so battery draining is expected.
If your screen on time is less than 5hrs then it's a serious issue. Check your device temperature if it exceed 40 to 45 degrees Celsius then there might be the damage inside your device mother board
Lakshay31
The screen-on time is approximately seven hours under typical usage, but the battery drains more quickly when using the camera. If I were to go on vacation and take many photos and videos, the battery would not last very long. I've observed a two to three percent battery drop after using the camera for only two to three minutes.
anilpss
Happy weekend
Lakshay31
Thank yoh for your reply.
I just hope it will improve with time and updates. I'm planning a vacation next month and will be taking many photos and videos. I'd prefer not to have to constantly charge my new phone.
goodthings
Lakshay31
