12-11-2024 11:27 PM in
Galaxy S- Mark as New
12-11-2024 11:28 PM in
12-11-2024 11:29 PM in
12-11-2024 11:32 PM in
12-11-2024 11:35 PM in
12-11-2024 11:44 PM in
12-17-2024 05:16 AM in
12-12-2024 12:06 AM in
12-12-2024 03:36 PM in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issue. However, we are taking your valuable feedback regarding this.
● Perform Battery Optimization: Battery optimization helps you to boost the battery performance of your device. To check battery optimization: Settings > Select Device Maintenance/Device Care/Battery and Device care > Optimize > Optimize all options like Battery, Storage, and Memory
● Turn off Wi-Fi, GPS, Bluetooth, etc.
● Kindly check whether the mobile network fluctuates frequently or the network signal is low in your area. In both cases, the battery will drain considerably fast. We recommend you avoid usage in areas with low network/fluctuation.
● Reduce display brightness level: Kindly set the device display brightness in auto mode;
* Steps for setting display brightness in auto mode: Swipe down on the home screen to open the notification panel
* Turn on the Auto brightness option if available.
* It will automatically adjust the display brightness of your device according to ambient light & will reduce the battery drainage.
● Adjust screen timeout settings: Settings> Display> Screen timeout> Select minimum screen timeout.
● Kindly check which application is or interface is using more battery from device care. And try to update app or avoid using that app.
● Kindly check which application or interface is using more battery from device care. And try to update app or avoid using that app.
● Turn off auto sync of e-mails, app data, etc. we request you to turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
● Steps to turn off auto sync are: 1. Swipe down on the home screen to open the notification panel.
2. Turn off the auto sync option.
● Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
12-12-2024 10:56 PM in
