S25 ultra battery performance
(Topic created on: yesterday)
Lakshay31
Hello everyone, please share the battery performance of your s25 ultra. How much SOT you were getting earlier and how much is it after the latest May update?
8 Comments
CaptainChiku
12 hours of SOT before the update but barely 5-6 hours of SOT after the May update.
S_Kumar73
Yes
Mani4
Please try to clear cache partition after booting in recovery mode, if not solved format, the device after backup. If it works, you can mark this as a solution, which will also help other users. To do so, click the three dots in my reply section and select "Accept Solution." Thank you!
Lakshay31
Please read the post 1st. Thank you
Mani4
ok, accepted but ultimate objective is same
Lakshay31
Do you have s25 ultra? Please share battery stats. I just want to know what others are getting. Some says that used to get more than 9hrs SOT and even upto 12 hrs but I never got more than 7-8 hrs
SHON_GEORGE
SHON_GEORGE
