Resolved! Solved
Light mode notification panel issues
(Topic created on: 05-17-2025 09:47 AM)
mystyy
I am experiencing an issue with light and dark modes on my Samsung Galaxy S23 Ultra following the One UI 7 update. The notification panel and lock screen are displaying in dark mode, even when light mode is selected. Has anyone else encountered this problem?
2 Solutions
ヅFedron
If you liked My Suggestion then click on three dots (⋮) on my comment and select "Accept Solution" 😊.
Ammitz
You can try change your wallpaper to some light background, then the difference is more noticeable.
14 Comments
Ammitz
No, works fine for me..
RIPA35
😮😮 why, please visit nearest Samsung service center 🙏
Ammitz
Maybe problem with your theme or something
mystyy
I haven't touched the theme settings, and I didn't customize anything.
Ammitz
Slight but noticeable difference is there..1747456421343.jpg1747456421360.jpg
mystyy
I see no difference on dark and light mode except the boundaries.1747456524051.jpg1747456655285.jpg
Ammitz
mystyy
Thanks for the suggestion but
I already fixed it.
ヅFedron
