Battery drain issue after one ui 7 update in s24 ultra
(Topic created on: 05-03-2025 05:28 PM)
praram_558
I am seeing serious issue with battery after one ui 7 update. It's draining in 3-4 hours. Earlier i used to get at least 8 hours
7 Comments
Amit3112
Don't worry.. I have also faced similar issue in my s24 ultra. After update it is significantly dropped. Only 4 hours of SOT.
But..
After a week it it's back to normal. Now I am getting 8 hours of SOT.
Just wait, device will optimize new software and everything will be fine.
praram_558
It's been 9days already. Worrying little bit. Anyway thanks for your response.
Amit3112
Ok.. I have done a factory reset after updating. While phone is learning usase pattern in device care, battery is draining like a hell. But once it's learned, battery seems to be improved.
How to factory reset without data loss?
Install samsung smart switch in both pc and phone. Open samsung Smart Switch in pc or laptop. Connect data cable.. make a backup of everything. It will create a backup. Now do factory reset from phone's setting. And set up it as a new phone. Again Install Smart switch in phone.. connect phone to pc with cabal.. open smart switch in pc.. and restore the backup.
This will took approx 2.. 3 hours in total.
Things to remember:
WhatsApp chat will not backup in Smart switch, so make a backup of WhatsApp chat in google drive before doing factory reset.
All the payment/ banking app needs to be set up again.
praram_558
It's lengthy process. I will wait for another 2days and if the issue still persist then will follow the above given steps.
Thanks
Amit3112
Ok
User28
S24 ultra. After One UI7 upgrade. Infact i am noticing lesser battery drain. Nope i did not do any factory reset. Just wipe cache partition from recovery menu.1746277588317.jpg
cs_member8
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
