S23 battery drains so fast after updating one UI 7
(Topic created on: 05-03-2025 05:44 PM)
GYANARANAJANJENA
My s23 battery is draining so fastly after updating one UI7.
5 Comments
Try these quick solutions😊:
1. Clear cache partition:
Power off > Hold Power + Volume Up > Select Wipe cache partition.
2. Check battery usage:
Settings > Battery > Usage – uninstall or restrict high-drain apps.
3. Enable battery saver:
Settings > Battery > Power saving mode.
4. Turn off unused features:
Disable Always On Display, 5G, Location, Bluetooth if not needed.
5. Update all apps: Outdated apps may drain more power.
Not applicable
If these options are turn off the phone would feel like a flagship one
yakinyadav
Same issue
RACE_IST
60hz power saving. And please try to appreciate the sheer performance.
cs_member8
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
