Battery drain issue after one ui 7 on my galaxy s24+
(Topic created on: 05-18-2025 09:57 AM)
Sri_Ram_Prateek
Drastic reduce in sot after one ui 7 update. Thought it will be nrml after some days of update but it's getting worse.
Edit: using it with location off, fhd+ resol., battery saver, lite performance modes but still less sot. Why samsung? Then what is the use of lite performance mode and battery saver modes?
13 Comments
tywap
Samsung is having a joke with premium s series users, now I understand why people choose apple
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
See limiting all the resources doesn't make sense. We bought the phone for all the features it provides. What is the point of getting more battery life without any of the features. I understand using all the features at once will drain the battery quicker. But see I have been using my phone in lite performance mode and battery saving mode and still getting less battery life means it's waste of having those features. I usually charge my phone over night turning off fast charging mode and in a AC room. With all my usage I am not getting atleast 6hrs of sot is a worst purchase. That too it is some what ok before update. It got worse after the one ui7 update. Worst experience samsung.
