Resolved! Solved
Battery drain issue after UI 7 update
(Topic created on: 05-26-2025 11:02 PM)
GeorgeJr000
Beginner Level 5
I have been using s23 ultra for a quite while and recently got the much awaited update of UI7 but the saddest part is after that battery starts to drain like hell... it's really disappointing and disturbing to charge the phone for 3 times per day even on normal usage. Hoping for an update which resolves this issue soon. Plss samsung 🙏🏻🙏🏻
Resolved!
11 Comments
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that we never recommend downgrading your device software, it may cause malfunctioning on your device. However, to downgrade the OS of your device we suggest you kindly visit the service center.
You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Meanwhile, please perform the below-mentioned troubleshooting steps, these may help in resolving your device battery drain concern.
9. Reset the device:
IMPORTANT:
• For this:
GeorgeJr000
Beginner Level 5
Instead of doing all these changes, better to keep phone aside and just look on to it. Right?
