Battery drain in s24 ultra
(Topic created on: 07-15-2024 03:39 PM)
Prince_2922
my S24 Ultra is Not giving a good battery life from the day of purchase. It hardly gives 23 hrs of battery life. The full charge doesn't increase.
6 Comments
Share the sot
Prince_2922
Turn on dark mode and select light performance profile. Keep connectivity features off when not in use. Decrease brightness
Sameer
Fix battery drain by following the steps in the video link below
https://youtu.be/DXM7pdW5a-w?si=y0K7mcyUM7J1HBEf
This video specifically created to tackle this issue.
Also make your phone run 2x faster
https://youtu.be/pgNi1Pmua3c?si=qICVccWjPuKAWIC7
Lot of exclusive content coming up on SammyTechWorld
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps in the link below.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Prince_2922
Can some body share their s24 u. Batteru info
