12-03-2023 10:27 AM in
Galaxy S- Mark as New
12-03-2023 10:34 AM in
12-03-2023 10:38 AM in
12-03-2023 04:54 PM in
Galaxy SI have downloaded the update but not installed because reviews for One UI 6 are not so good specially if there is a screen burn-in issue
12-03-2023 08:20 PM in
Galaxy Skindly manually check in settings--system update---you might got OTP update
12-03-2023 10:55 AM in
12-03-2023 11:46 AM in
12-04-2023 09:57 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps by a given link to resolve your issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue still occurs kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
