Battery drain after January security patch
(Topic created on: 01-20-2024 09:55 PM)
KrishanC1997
Why S23 ultra draining battery like **bleep** after January update? Its very significantly noticable.....I mean its like getting 10% less battery than before....anyone facing the same?
13 Comments
goodthings
Complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue. Then wait for next update may be fix it by Samsung team soon. Thanks.
AJAB_MORIA
Some updates are such that it takes some time to adjust with the phone. Wait for next update, it will be fixed.
Restart your phone (in your free time) to avoid such problems.
sdm0ippb96
There is too much bleach in this security patch update.
KrishanC1997
Seriously....too much...
Members_9pIc8Vt
Same here. Seems like Samsung really wants us to ditch our old phones and "upgrade" to the newer models that are just around the corner. I mean it just can't be a coincidence right?
They are low key copying apple strategy... make the older device little slow and reduce battery performance
KrishanC1997
Literally s23 ultra had such battery that even 2days backup is cakewalk for it....but after January update...its draining like hell....
cs_member10
Dear Samsung Member,
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue persists kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
ArunMV
Exactly I am also facing battery drain after one UI 6. 100% sure.
