S23 battery drain?
(Topic created on: 02-18-2025 06:31 AM)
Saahil_1205
I am recently observing a lot of battery drain in my s23, after the january security patch, I am barely getting an SOT of 2 hours and the battery overall lasts for only 9 hours ( 80 -20 %). Is there a way to optimize the battery? Please help.
6 Comments
Mahendra10
Your name ?
NoNameFound
u use in thick cover? s23 is compact and only around 3700 mh battery so much load get by proccecer or when it in thick cover so innerly heat and battery effects on battery health, i know processor is efficient but plus heat and load , effects on battery
Saahil_1205
I use a magsafe silicone cover.
NoNameFound
i even ultra thin cover, its also heat in it, which i buyed in 800 rupees, better to use that, in if u use phone in blanket or anything, that will heat even without cover, u feel like phone not heating but when u remove cover u feel warm and i checked the bettery tempreture many times its 40c plus many times , try to control in 40 c, s23 is for that users who want compact device and can manage with battery
aniket-n
Few things, I can suggest. You can decide based on your usage.
1. Set your refresh rate to 60Hz.
2. Use 4G in stead of 5G (Optional).
3. Disable "Nearby devide scan" option.
4. Set your performance profile to LITE.
cs_member10
Dear Samsung member,
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
