Battery drain S20
(Topic created on: 01-24-2021 07:50 PM)
ChintanBhakta
Does any one having problem of heavy battery drain in Galaxy S20 after upgrading to android 11..I need to charge my S20 3 times a day..Even at night time battery reduces from 100% to 40% between 11 pm to 6 am
8 Comments
Not applicable
possible....because may be you simply install software via mobile data or wifi where the recommended process is to flash that firmware from service center or install software via smart switch and pc to avoid software loop holes.... Samsung provides non A/B system partition ota so anything mysterious can happend if by chance that software not installed fully or correctly via simple upload
Not applicable
visit service center and flash firmware. your device all issue will solved
Ehsank
If after update then wait for few days, and as of now perform these below steps;
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable and connect withpc/laptop/type C earphone only for Android 11 )
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
Ehsank
further if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Ehsank
You can also send feedback to Samsung by using get help section
GetHelp>>SendFeedback>>ErrorReport/AskQuestion>choose appropriate section
anupbharadwaj
simple backup your data and factory reset device and let me know if problem is solved restore only data you use and avoid some non using apps in ur phone
ChintanBhakta
i will let u know once i do it
cs-member13
Expert Level 4
Dear Samsung Member,
We are sorry for the inconvenience caused to you. We request you to kindly send us the error log file again along with the Video or Screen-shots within 15 minutes of issue occurrence through error report section from Samsung Member Application:- Samsung member > Click on beta banner > Switch to beta mode > Beta feedback > Send feedback > Error report. As this will help us to further investigate and resolve your concern.
